Car starts the moment you connect the battery post.
but will not turn off, unless
you kill it with the clutch
or by disconnecting the main power relay.
replaced push button but resulted the same
replaced keyless module but does not allow registration
because you can not turn on the power.
and when with autel 906ts,
will not register because you can not turn off with push button
to continue the process.
