7 seconds
Usually no, since the system puts a focus on gaining traction which in the process can cause the vehicle to not move as freely.Shouldn't the time be better with TC?
6.8-7.2 seconds is not only pretty good, its the best in class, even surpassing a 2.5l mazda 3 with a manual 6 speed vs a cvt!It's interesting that between this, MT and other reviewers have all gotten different numbers, the best so far being 6.8 seconds in the touring. MT got the slowest time i think at 7.2ish... so we can assume depending on the road, traction, the weather conditions at the time 6.8-7.2 seconds. That's pretty good for a economy car in this class and definitely better than the current cars 8.2-8.6 times.
Also, the cars being tested are the heavier models, one can assume lower trims like the EX-T will be slightly quicker due to less weight than the touring model, same goes for the coupe potentially shedding a few extra pounds could make the difference of a few tenths of a second here and there.
It is very good considering also that's faster than the CVT equipped base i4 accord and only about half a second or so off from the current gen Si. Which is just more reason for the new Si to get the detuned turbo with 230+ hp.6.8-7.2 seconds is not only pretty good, its the best in class, even surpassing a 2.5l mazda 3 with a manual 6 speed vs a cvt!
I'd say its mostly equal in speed to the current Si. The trap speeds for both of them are about 94 mph.It is very good considering also that's faster than the CVT equipped base i4 accord and only about half a second or so off from the current gen Si. Which is just more reason for the new Si to get the detuned turbo with 230+ hp.
It doesn't have paddle shifters, and the other thing about this particular 0-60 test is that they used the sport mode which simulates gear changes... it's actually faster in normal drive mode because it doesn't lose time to those gear changes and stays in the top rpm range as you mentioned. Most tests i've seen looks like sport mode actually costs the car anywhere from .2-.5 seconds to 60mph.Does it have to be paddle shifted or can it go straight to top rpm and stay there? Hate that paddle shifting!
