Seems like Civics produced between September 22, 2015, to February 3, 2016 is an awful lot of Civics. This is going to be a big recall.
Exactly how big:Seems like Civics produced between September 22, 2015, to February 3, 2016 is an awful lot of Civics. This is going to be a big recall.
Potential Number of Units Affected: 42,129
So your civic could potentially be at the dealership for a long while if it damaged the engine block because the warranty inspectors will need to be called in.Inspect the piston pin snap rings. If there are any that are not completely set or missing, replace the affected piston
rings and snap rings. In rare cases the piston pin(s) may damage the engine block, requiring replacement of the engine
short block. Replaced short blocks will be called into Warranty Inspection to confirm the damage.
If they find nothing wrong, they send Honda images of all eight snap rings. If they find a snap ring incompletely seated or missing and no subsequent damage, they call Honda and send Honda the images and get new piston set and replace them. If they find cylinder damage, they call Honda and send Honda the images and get new short block and replace it. All of this is outlined in the service bulletin.So your civic could potentially be at the dealership for a long while if it damaged the engine block because the warranty inspectors will need to be called in.
On the plus side, after doing a couple of those jobs, it gets easier and faster to complete = more units to rack upGlad I'm not a mechanic, they have to remove so many parts just to get to the rings.
Since most cars just get the inspection, it's not too bad. They drop a skirt panel, the exhaust, and a few ancillaries, remove the oil pan, baffle, and pickup. Take the borescope, take eight images of the snap rings, and button it back up. Honda is paying 2.5 hours if no damage is found. Somebody good who does a lot of these is going to be doing it in 1.5 by the last one.Glad I'm not a mechanic, they have to remove so many parts just to get to the rings.
Can someone post a picture of what this "clip" looks like and the location of it under the hood? Would a person know if something is loose just by driving the car?2016 Honda Civics Equipped with 2.0L engine
RECALL Subject : Piston Wrist Pin Circlips may not be Secured
Report Receipt Date: FEB 09, 2016
NHTSA Campaign Number: 16V074000
Component(s): ENGINE AND ENGINE COOLING
Vehicle Make Model Model Year(s)
HONDA CIVIC 2016
Manufacturer: Honda (American Honda Motor Co.)
SUMMARY:
Honda (American Honda Motor Co.) is recalling certain model year 2016 Civic vehicles manufactured September 22, 2015, to February 3, 2016 and equipped with 2.0L engines. The affected vehicles have engines with piston assemblies that may have been manufactured without a piston wrist pin circlip or with an incorrectly installed piston wrist pin circlip.
CONSEQUENCE:
If a circlip is missing or incorrectly installed, the piston wrist pin may not be secure and may drift and damage the engine cylinder causing the engine to seize, and increasing the risk of a crash or a fire.
REMEDY:
Honda will notify owners, and dealers will inspect and replace the piston assemblies and damaged engine components, as necessary, free of charge. Parts are expected to be available in the Summer of 2016. Owners will be mailed an interim notification beginning March 31, 2016, and will be mailed a second notice when parts are available. Owners may contact Honda customer service at 1-888-234-2138. Honda's number for this recall is JX9.
11 Associated Documents:
Recall Acknowledgement
Recall 573 Report-Amendment 3
Defect Notice 573 Report
Manufacturer Notices(to Dealers,etc) - Stop Sale/Safety Recall: 2016 Civic Piston Pin Snap Ring-AFFECTED RANGE UPDATE
Manufacturer Notices(to Dealers,etc) - Date: January 30, 2016 Subject: Stop Sale/Safety Recall: 2016 Civic Piston Pin Snap Ring
Manufacturer Notices(to Dealers,etc)- Stop Sale/Safety Recall: 2016 Civic Piston Pin Snap Ring
Manufacturer Notices(to Dealers,etc) - February 19, 2016 Stop Sale/Safety Recall: 2016 Civic Piston Pin Snap Ring-PROCEDURE UPDATE
573 Report
Remedy Instructions and TSB - Service Bulletin 16-017 February 20, 2016 03188 Version 2
Remedy Instructions and TSB - Honda Service Bulletin 16-017 January 30, 2016 03188 Version 1
Interesting. The nominal inspection case only pays the dealer 2.5 hours of labor to do the job. How many part numbers were listed on your RO? Did they have to do more than just the inspection?I luckily already had this fixed on my vehicle, it took them 2 days....
