Im having the same problem. Its intermittent. But occuring more. Also the door wont lock at all. 52k on the car. 2016 Honda Civic Ext
I have a door lock/entry issue with my 2017 Honda Civic. It's been back to the dealer 3 times but no result. Here's what happens:
It's intermittent (about once per month)
Locking system is set to proximity lock
Walk up to the drivers door and touch/pull handle - nothing happens. Pull out the key fob and press unlock. All the doors unlock EXCEPT for the drivers door. Press lock, then unlock. Same result. Only way I found to get the drivers door open in this circumstance is to walk round to the passenger door, get into the car, reach across and pull the drivers side inside door handle. Once that is done the drivers door lock/unlock works normally again.
Dealer has already replaced most of the drivers door lock components but no result.
Is anyone else seeing this or is it just my vehicle??
