1 - 20 of 20 Posts
This one time merging on to the highway in "mexico" I hit 135 in 5th and it still had more to go but I had to let off.
The non SI models with governor removed are hitting the mid to high 160's. That's too fast for a stock Civic, upgrades needed to be safe at that speed!
I wouldn't try it. Aerodynamics are what will kill you. Possibly literally.
I have a supercharged '95 Civic, and found a stretch of nicely paved highway that even went downhill with visibility to spot the 5/0 for miles - so I punched it from the top to see what I could get to. Somewhere around 130 things simply start to get squirrelly, and that was with the car having a pretty solid suspension (Neuspeed sport springs, Koni shocks, and a ST anti-sway kit, although that doesn't come into play at straight speeds). The car will start to drift around, and that has nothing to do with the suspension - it has to do with the car starting to lift off the ground.
Perhaps if you drill out (or remove) the rear bumper, provide a larger outlet opening than the combined front air inlets / front bumper gap provide, then you can create the suction force to keep the car planted. The new cars do come with some plastic under-belly pans, but I don't know anyway how much of a role they are designed to play for high speed aerodynamics - I suspect they exist more to smooth the underside in the pursuit of better fuel economy, which may actually decrease rather than increase downforce.
Just saying, I wouldn't play that game - besides the ticket, you'll find very few sympathetic to a headline that reads "car estimated to have flipped over 10 times, occupants inside killed at the scene of the crash".
Car's too light and not enough downforce, so I won't be experimenting anytime soon. The car likes to move in the lane when there's the slightest of crosswind at 75mph; don't want to know what that'll be like at double the speed...
Discussion Starter · #12 ·
I heard through the grapevine that it's governed at around 138mph and feels perfectly planted and smooth at that speed with no handling issues that stick out. Maybe someday I'll actually get to try it out for myself. *wink* *wink* ;) 0:):D
They'll hit 160mph with the stock horsepower?
Only in somebody's dreams. No way you get an Si up to 160 even with an extra 15 - 20 hp which is all you can get out of a simple reflash. Although many people will claim to get more, they never show the actual dynamometer output. Talk is cheap but increasing Si top speed to 160 is not...
Got up to 140 in a bone stock 2018 SI Coupe, let off due to instability. Car starts to lift at around 120, there's just nothing keeping you on the ground.
well today my 2020 si wit full bolts ons nd tune from hondata hit 151mph on a long straight away on the highway i let off because i have no internal mods on the engine and i was at 6100rpm at that speed so didn’t wanna risk redlining this tiny engine 150+, but my car felt planted and stable during that pull only started to feel pretty wobbly once letting off the gas most likely won’t be doing that again but it was midnight wit no other car in sight so i was curious to see what i can top out at because last time i sent it i was stock and capped out at 136mph so just wit bolt on nd a tune hitting 151 is pretty impressive to me but still wouldn’t recommend it unless u have a built motor along wit it
My stock 2019 si coupe goes 137. I don't think it is governed at that speed, I just don't think it has enough H.P. and torque to overcome wind resistance and inertia to push past that.
My 19 si FBO topped out at 168. Factory speed limited to 138 which is coincidentally the top of 5th. Gets to the top of 5th quick then the last 30mph in 6th takes a few more seconds. The '20 and '21 have a 5.6% shorter FD ratio so they would redline at about 158 mph tuned.
Didn't run it to 6k in this pic but knock is still perfect .49 on a cool day with only 24% ethanol.
1 - 20 of 20 Posts
