Hey, My name is Kisha. I wondering if anyone has experienced this problem with their Civic. I brought a 2018 Honda Civic ex in Dec. Now that it summer time in South i noticed that my a/c isn't keeping up with the heat. It will get cold when the temp outside is cool but when its hot it doesn't get cold. Its feels very mediocre. Any suggestions on what it might be? I was told that it maybe leak somewhere and it would cost $220.00 for a recharge by a Honda shop near me.
DO NOT pay to fix this. It sounds like your AC condenser is going bad. The early 10th gen Civic condensers were poorly designed. Honda recognized this and extended the warranty on that part to ten years. If you take it to a dealership and there is no sign of external damage such as a rock hitting it (which is unlikely) then it will be replaced at no cost to you. This has happened to a lot if 10th gen owners including me so I know from experience that it can be fixed for free. I have a 2018 ex-t and my AC did the exact thing you are describing at about 40,000 miles. You shouldn't have any problems getting this corrected. It took my dealership about two hours to complete the work. Just make sure the receipt they give you when it's all done has the new condenser part number. I can't remember the whole thing but the old part has A01 in it and the new one will have A02. Hope this helps.
Well, I did but they said it wasn't a leak. I ended up selling it. I. got over $4,000 in positive equity.
It's an ac condenser leak I just got mine replaced
Discussion Starter · #5 ·
Ok, They checked mine the dealership but couldn't see anything. I ended up selling it and getting a 2018 Honda Accord Ex-L. It's soooo much better! I'm definitely happy with this purchase. I believe it had to blow out warm air in all the vents instead of one to get it replaced.
You might want to check the condenser in your air conditioner. Of course, it's easy for any air conditioner to blow cold air when it's winter outside. You might as well drive around in your car with the window open for a breeze, haha. You should contact air conditioning repair st petersburg fl to have them fix the hot air problem. That's probably the only thing you can do if you don't know about air conditioning and want to improve your car or air conditioner yourself. Best of luck to you! Hopefully, you'll be walking into a cooled vehicle in the summer heat soon.
