Hi, I have Honda civic 2016, it was hit from front but not too much damage other than bumper and radiator, driver airbag deployed, after I done with repairing I have now abs, steering power, tmps, brake (for electric brake) and vsa are ligts on in the dashboard.
I checked with scanner and giving me only miss communication with steering angle sensor!
I called dealer and they told me that it doesn't come with this car!! there is no SAS for that car!!
Do I have to try to replace clock spring sensor or what? do you have that problem before?
Thanks.
Thanks.
Support the front of your vehicle on jack stands and remove bottom cover under your engine. Visually inspect for any pinched wires or harnesses around the area of your steering column connecting to your power steering rack.
