vBToucan.com Vendor
The creation of the all-new SP-Series system for your Civic Si was inspired by the strong racing heritage that stands behind this legendary brand. The new intake is an application-specific system, engineered to remove the restrictions on the way of the airflow to your engine and maximize the power gains. As per the manufacturer, you’ll get faster acceleration and much better fuel economy at cruising speeds.
The installation process is easy, as this is a bolt-on upgrade that requires no drilling or cutting to be attached properly. The SP Series Intakes are pretty compact and will easily install under the hood of your Civic Si.
Injen - SP Series Wrinkle Red Short Ram Air Intake System with Blue Filter
Fits: 2017-2020 Honda Civic Si
Includes:
  • Intake Tubing
  • Filter
  • Heat Shield
Features:
  • Improves airflow into the engine
  • Uses the patented MR Technology tuning process to ensure the air/fuel ratio is within optimum limits
  • Increases horsepower
  • Improves acceleration and fuel economy
  • Easily installs under the hood
  • Every system includes the EA Nanofiber dry air filter
  • Air intake pipe constructed of mandrel-bent 6061 aluminum for smooth airflow
  • Comes complete with all necessary mounting hardware and comprehensive installation instructions
  • Backed by a Limited Lifetime Warranty
Click here to get more information about the new Injen Product.
