1 - 7 of 7 Posts
Clock/Wallpaper Setting?
In settings you can set the clock type and wallpaper that goes behind the clock, however, where does this show up when its set? MY main screen is always either on Home, Android Auto, or the radio.. is this where that setting would show up? if so, how do you access it? I have seen photos of the Accord and the clock with wallpaper shows up on the upper level screen. Just wondering if this is just built in across all models and only accessible on those that have the second upper screen?
Your Civic comes with two "skins" installed, not all options are available in each skin so you need to play around with them and see witch one you like best. To change skins goto settings/system/change skin. This second skin is where you can change the background on the clock.
Nice, didn't even know it possible, obviously when I leased at DSRLeasing my friend didn't even mention all the features. Thanks for this, I'll check it out.
1 - 7 of 7 Posts
