Here's an official breakdown on the long list of interior features and how some of them work.
Overview
The new Civic brings an elevated level of comfort and convenience to an affordable, compact-class car, with numerous Civic firsts and standard or optional premium features typically found in more expensive vehicles. From the convenience of available Smart Entry and Pushbutton Start/Stop to the ease of use of the new electric parking brake and Hill Start Assist, the Civic offers useful technologies that make driving easier and more convenient.
Key Comfort and Convenience Features
Smart Entry and Push Button Start (available)
Remote Engine Start* (available)
Hill Start Assist
Auto-Dimming Rearview Mirror (available)
Driver Preference Settings* (available)
Capless Fueling System*
Electric Parking Brake*
* First for Civic
^ First for Honda
Smart Entry and Push Button Start/Stop
The 2016 Civic offers the upscale convenience of Smart Entry and Push Button Start/Stop.
Remote Keyless Entry
Remote keyless entry is standard equipment on all Civic models. The wave key design (LX trim) has an integrated transmitter in the handle with lock, unlock, trunk open and panic buttons.
Smart Entry
Smart Entry also allows the driver to approach, open and use the trunk without using a key or pressing a button on the remote. With the remote in his or her possession, the driver simply presses the release button and opens the trunk. As a safety and convenience feature, the Smart Entry system will not allow the transmitter fob to be locked in the interior of the Civic.
Push Button Start/StopOn the Civic EX and above, once the driver has opened the door and is seated, the driver simply pushes the START/STOP button positioned on the instrument panel while pressing the brake pedal to start the vehicle. Powertrain operation and certain electrical functions are ended when the START/STOP button is pressed again at the conclusion of the drive. For accessory mode, the driver simply presses the START/STOP button without pressing the brake pedal. The new Civic's START/STOP button features a pulsating light to help the driver more easily locate the button.
Remote Engine Start
Civic EX trims and above feature standard remote engine start. This enables drivers to start their Civic in advance of the drive, thereby activating the climate control system with a target temperature of 72 degrees before they get to the vehicle – particularly helpful in extreme hot- or cold-weather conditions. The system will automatically operate the heater, front and rear defrosters, front heated seats (if equipped), heated side mirror, and air conditioning as needed.
The remote engine start feature is built into the key fob supplied with the vehicle. To start the engine remotely, the owner presses the LOCK button and then holds the ENGINE button for a second. The Civic's hazard lights will flash, indicating that the signal has been received. When the engine is started remotely, the wipers, lighting and audio systems remain off, and the security system remains set. The engine will run for up to 10 minutes after remote starting and can be extended by another 10 minutes using the same procedure, and then shut off automatically if the owner doesn't reach the vehicle within that time. When the owner does get to the Civic within 10 minutes, or extended period if the procedure is initiated a second time, the engine will keep running while the owner unlocks the vehicle, gets in, applies the brake and presses the Civic's START button, which turns on all of the vehicle's systems.
Driver Preferences
The Civic EX and above trims come with two keyless remotes with unique identifiers. Each remote can be set with unique profiles to accommodate the individual preferences of two different drivers. The available preferences include driver seat and mirror positions. Other preferences include audio system pre-sets, air conditioning preferences, and navigation system settings. In the event both owners use the car at the same time, the Civic will recognize the keyless remote that approaches the driver's door first.
Locking
After parking, a press of the LOCK button on the remote will simultaneously lock all the doors and trunk. On EX and above trims a touch of the soft-touch lock button on either front door handle locks all doors and trunk to secure the Civic. The system will not allow the remote to be locked in the interior of the Civic.
Walk Away Door Lock
Included on EX and above trims, the new Walk Away Door Lock feature automatically locks the Civic when the driver leaves the vehicle. This hands-free locking capability adds everyday convenience that's especially useful when the driver has his or her hands full or is distracted. In typical use, when all doors are closed and the driver walks away, the Civic will automatically lock when the key holder's distance from the vehicle exceeds 6.5 feet for two seconds or more and when no other key is detected inside the vehicle. An audible buzzer sounds and the hazard lights flash to confirm that the vehicle has locked. The Walk Away Door Lock feature is programmable, and may be turned on or off as the driver prefers.
Auto On/Off Headlights
All Civic models feature auto-on/off headlights for greater convenience. The headlights are multi-reflector/projector-beam units on all Civic models except the Touring, which has auto-on/off LED headlights. All Civic models feature dramatic LED Daytime Running Lights (DRL).
A Civic first, the EX-L and Touring Sedan models feature an electrochromic interior rearview mirror that automatically dims during nighttime driving to reduce glare from the headlights of following vehicles.
Capless fueling eliminates the fuel cap, meaning that fueling the vehicle simply requires opening the fuel lid, refueling, and then closing the lid. This smart and easy-to-use design eliminates the need to touch a dirty fuel cap, reduces the possibility of damaging the vehicle's paint with the fuel cap or tether, or forgetting the fuel cap at the gas station. It also eliminates the possibility of activating an emissions warning by failing to properly re-install the fuel cap. And finally, the capless fueling system allows the use of a smaller fuel-cap door, which cleans up the lines of the vehicle.
The system consists of two integrated components, an outer shutter mechanism that prevents the intrusion of dirt and dust, and a self-sealing fueling flap that is closed by a torsion spring. Both operate automatically.
At a gas station, the driver simply pushes the fuel lid to release it and then inserts the fuel nozzle. Inserting the nozzle automatically opens the outer shutter and fueling flap. When fueling is complete, removing the fuel nozzle automatically closes both the fueling flap and outer shutter.
Electric Parking Brake (EPB)
The Civic's Electric Parking Brake makes using the parking brake easier and more comfortable and frees up precious center console space for storage and other functions.
Hill Start Assist
The Hill Start Assist function helps to prevent the vehicle from rolling backwards when the driver switches from the brake pedal to the accelerator pedal while the vehicle is stopped on a hill.
Overview
Hill Start Assist
* First for Civic
^ First for Honda
Smart Entry
Remote Engine Start
Driver Preferences
Locking
Walk Away Door Lock
Hill Start Assist
