Cool stuff. Any recommendations on where to buy these bulbs?
yep! same bulbNice. Did the trunk took the same bulbs?
thank you!Looks really good!
They look great. Do you plan to change any of the others, like the license plate light? I'm guess that's also the same bulb.yep! same bulb
Thank you! It's actually very white but the phone couldn't really capture the true color even in manual mode. I turned the iso up a little but the factory camera app didn't have the options to change its settings. Very white though.looks great! Is it actually that purple/blue in person?
Thank you and you're welcome. I hope to add more DIY's for us who like to do things for ourselves.Nice DIY write up. Thank you for sharing !
Maybe the powers to be can create a Mod section for these DIY write ups.
I found this package to change all your lights, on ebay for under 15 bucksCool stuff. Any recommendations on where to buy these bulbs?
This set fits everything inside your carthe pic of the LED bulb you posted , is that the exact length that can be used in the housing or cann we use one that slightly longer? ive been using LED bulbs from aznoptics.com in my cars since ive never had issues with them for atleat 4 years now. ive seen used other cheap bulbs and LED's would burn out. when i swap out the ones in the civic i just want to do it once and not worry about having to keep changing them.
