This is probably a question for the owners of the 2016 Civic's. Do you guys know if the DRL's can be replaced? I'd like to change them to a different color once I get one.
Thanks. I want to modify it the way I have it on my 2007 Civic SI now. I'd replaced the high beams with 194 LED bulbs and connected it to a photocell and relay with my headlights as the off switch. So when I have it parked at night, it glows red. I plan on getting the Type R. So imagine those DRL's glowing red at night.I'll Check on that, cause that sounds very interesting. I'll get back to you if no else replies first.
Thanks for checking. Looking at the diagram of the headlight assembly, it's not showing any bulbs though.hey sorry for the delay but i checked on your inquiry and yes they can be replaced, in fact though i did not pull out the bulb they are very easily accessible. a lot of space for ballast for future hid installation.
