Finally found some engine info by looking at Window Stickers and doing a lot of web searching. Thought this might interest some of you. I know I was wondering.
2016 Civic Sedan EX-T uses the L15B7 engine.
L15B7
Found in:
2016 Honda Civic turbo (US)
Engine Type: In-Line 4-Cylinder with Single Scroll MHI TD03 Turbo and Internal Wastegate
Boost Pressure: 16.5 psi
Displacement: 1,496 cc (91.3 cu in) Direct Injection
Bore and Stroke: 73.0 mm x 89.4 mm
Compression: 10.6:1
Power: 174 HP @ 6000 rpm
Torque: 162 lb·ft @ 1700-5500 rpm
Redline: 6,500 rpm
The normally aspirated 2.0 liter engine used in the 2016 Civic are K20C2 engines.
K20C2
Found in:
2016 Honda Civic (US)
Displacement: 1,996 cc (121.8 cu in) PGM-FI
Bore and Stroke: 86 mm x 85.9 mm
Compression: 10.8:1
Power: 158 HP @ 6500 rpm
Torque: 138 lb·ft @ 4200 rpm
Redline: 6,700 rpm
The engine specs come from Wikipedia so take them with a grain of salt. The engine designations come off window stickers I saw at the dealer or on line.
I believe the Civic Type R engine is the K20C1 and I cannot find anything on the future SI engines which is rumored to be a detuned K20C1. My guess it will be called a K20C3 which would mirror what happened with the EP3 Type R/Si models. They had K20A and K20A3's respectively.
L15B7
Found in:
Compression: 10.6:1
Redline: 6,500 rpm
K20C2
Found in:
Compression: 10.8:1
Redline: 6,700 rpm
