1 - 7 of 7 Posts
amazon has a set....that states they don't hyperflash....but, all LED's that i am aware of will hyperflash in the turn signals unless you add the resistor.
amazon has these...if you want to try and report back to everyone, i'm sure hundreds, maybe thousands would be very appreciative. https://www.amazon.com/Amber-Error-Resistor-Required-Signal/dp/B00AOG01TU
These are also available to try: https://www.ebay.com/p/?iid=321836343272&lpid=82&&&ul_noapp=true&chn=ps
the ebay version is what i would be interested in as a solution...i dont' want to cut into my wiring and have any sort of issue with lights down the road.
You can still use your current LEDs. You will need to change to a digital flasher. The digital flasher will solve the problem and work with any non-LED bulbs you have. This something I learned from modifying my motorcycle turn signals.
1 - 7 of 7 Posts
