hi, so I purchased some insane cosmis racing wheels and I'm running a 275/35r18 which I now are wide, but the issue I have is the rear spring is to soft. Every time I have weight in the back it rubs my fender and has started to cut my wheel. Being that said I know that just lowering won't solve my problem but I just want to know if anyone runs similar set up with a camber kit, and does it clear fine in the rear. Also did you just lower and added camber or just ran a camber kit to avoid the same problem any feed back would be great thank you.
