From what I read there is a release inside the car. It cannot be opened by anyone.read one of the features was no gas cap. i like this.
push the lid in and it opens.... my concern is the apparent lack of a lock?
its just capless...Does anyone have a picture of this gas cap? It's the first time I'm hearing about it.
what if you're in proximity but not putting in gas... then anyone could siphon it off if they really wanted toMy guess is with the vehicle detecting the key, you can open it, if the key isn't around then you might have trouble. That is at least how I think it should ideally work
LOL please... are you telling me we're so progressive even a simple gas door release isn't good enough for us anymore?If it requires a button to activate then it should function based off of that with the key around allowing it to be activated.
http://content.usatoday.com/communi...fillers-may-thwart-gas-thieves/1#.ViZYLX5JaM8Ford says its capless filler deters gas theft in two ways: A spring-loaded flapper is held closed by latches that can only be released by a standard-size fuel nozzle. When a proper nozzle is inserted, the latches release, and the nozzle pushes the flapper door open. When you remove the nozzle, the flapper snaps shut. If a wrong-size nozzle or foreign object, say a garden hose, is inserted, the latches won't release.
Soon to be investigated by the NHTSA...Actually guys, If the Honda capless is anything like the Ford one siphoning gas will be next to impossible...
Well that's going to make running out of gas a much bigger deal. So now I'll to call a tow truck to come take me to the gas station because the gas can nozzle won't go into the filler?Actually guys, If the Honda capless is anything like the Ford one siphoning gas will be next to impossible...
Good that was only once and I hope you don't allow fuel levels to go really low since that can damage the fuel pump, which in the end can cost within the hundreds for replacing it (including labor)Well that's going to make running out of gas a much bigger deal. So now I'll to call a tow truck to come take me to the gas station because the gas can nozzle won't go into the filler?
I only ran out of gas once, and I learned my lesson, but it does happen.
