There's a good chance that can happen to meet the growing MPG standards and still deliver great power but then honda might avoid that just to ensure reliability. I really wouldn't mind a high output naturally aspirated 4 cylinderI really want to know If the new civic will be turbo charged. That is my biggest reason for waiting to see if it happens. I'm waiting on a new si
It's looking to be a bit more possible of happening as today some automotive publications have mentioned honda may be bringing over some of what we want from the Euro Type R:I really want to know If the new civic will be turbo charged. That is my biggest reason for waiting to see if it happens. I'm waiting on a new si
The 2.0-liter turbocharged, direct injected “Earth Dreams” four-cylinder engine set to power that car will be offered in an updated version of the Civic sold in North America according to a report by MotoryRacing. The report also claims that Honda wont stop at dropping the engine into the current Si model, but that it will tune the U.S. spec car for performance more in line with the hi-po engine and that the model could even wear a Type R badge.
Supposedly, the car will be introduced next spring and if that turns out to be the case it could mean the hopped up Civic showing up for the 2016 model year.
A Honda representative was not available to comment at the time this story was written.
My 2007 Fit has a L15 engine. Boosting it conservatively (like a stock tune) yields like 130whp. More boost can see numbers in the area of 170whp. I doubt Honda would give a big car such a small engine, boosted or not.I think the 1.8L will be replaced by a boosted 1.5L .
The non-Si models will definitely have engines under 2.0L. My guess is that Honda is aiming for 150 horsepower, 160 at best. There's no need for the base models to have big blocks. That's what the Si and Type R are for. There have been rumors that Honda plans to boost all Civics all across the board for some time now. I'm absolutely down with more power/torque and better fuel efficiency.My 2007 Fit has a L15 engine. Boosting it conservatively (like a stock tune) yields like 130whp. More boost can see numbers in the area of 170whp. I doubt Honda would give a big car such a small engine, boosted or not.
Yeah that would put it in line with what the current model is like, but of course doing a bit better than that is always a good thing:The non-Si models will definitely have engines under 2.0L. My guess is that Honda is aiming for 150 horsepower, 160 at best. There's no need for the base models to have big blocks. That's what the Si and Type R are for. There have been rumors that Honda plans to boost all Civics all across the board for some time now. I'm absolutely down with more power/torque and better fuel efficiency.
that sort of power in a civic that's lighter would be great, lighter than the outgoing model (2754 / 2811), but in saying that I might be asking for too much.Engine
Engine Type:
Displacement:
Horsepower (estimated):
Torque (estimated):
Differential:
Clutch:
Chassis
Front Brakes:
Wheels:
Tires:
Suspension:
Supercharged In-line 4-Cylinder
1497 cc
197-hp* @ 6250rpm
176 ft-lbs* @ 4850rpm
Advanced Limited-Slip Helical Gear Type
Carbon Semi-Metallic Six-Puck Street Performance Type
4-piston Aluminum Caliper / 300mm, Directionally-Ventilated Rotors
18-Inch Alloy Wheels
P215/40 R18 89Y
Lowered by 10mm
Front Spring Rate: 26.3 N/mm (150 lb/in)
Rear Spring Rate: 29.4 N/mm (168 lb/in)
