HDMI cable needed for CarPlay?
29904 Views 17 Replies 15 Participants Last post by  Deathklok
I'm buying my daughter an EX-T for her birthday and pick it up in a few weeks. The salesman says she'll need an HDMI cable to use CarPlay, but I think I've read elsewhere that no cable is needed and her phone (iPhone 6c) can be connected via Bluetooth on the 10th gen civics - which is correct? Thanks!
1 - 18 of 18 Posts
2016 dosen't have HDMI socket she can connect the her phone with bluetooth and usb cable
I have never heard of a car having an HDMI input for phones
While some phones (Samsung) Have HDMI capability, Apple does not, nor does the Civic.
You just use the USB Charging cable to connect. I'd be suspect at buying a car from a salesperson that stupid that they don't know that.
Thanks for all the replies!
Yea my girlfriend uses the car play and she just hooks it into the usb that is under the console, not the one under the cup holder. And it works every time! Just make sure you have a quality usb :)
The Hondalink iOS cable is used to display the nav part, but not compatible with 2016 Civic...only 2014 - 2015:
https://hondanavi.navigation.com/sku/U8819-0133-311/en_US/HondaNA/USD
Why compatible with previous Civics, but not the 2016?...stranger than fiction.
It's worse than that. With a simple exploit it's possible to fully mirror a phone onto the indash screen on a 2015 through the HDMI.
And yet, not compatible with current model...hmmm. Wife has new '16 Pilot, and it's also incompatible...whiskey tango foxtrot?
Quality is key, some people cheap out and buy $1 cords but spending the $10 for something from Best Buy is your best bet, better than dealing with issues. Even better if it's a tangle free cord.
Salesman probably meant a USB cord.
I thought Apple Car play would be wireless through bluetooth, but it's not you must have a USB cord to connect the phone to the car.
At least as far as I could tell the 24 hours I test drove one.
You should be able to connect to carplay via bluetooth with the iPhone but you can check here first to see if it's compatible. http://handsfreelink.com/Honda/en-US/US/FindAPhone
You will need a lightning to usb cord for your iphone to work with carplay. I plug mine into the usb port under the radio dash. It works great, however, I would recommend using an original Apple OEM cable. I tried a knock off and the carplay seemed a little squirrely so I switched back and have had no problems with carplay.
Streaming audio and phone will work on bluetooth alone, but to run the actual CarPlay app and move all the data for maps and w/e other apps you are running they require the use of a USB cable. It is the same for AndroidAuto.
I'm buying my daughter an EX-T for her birthday and pick it up in a few weeks. !
Wow..Very cool...and very generous Dad.
~~~~~ I remember one year I got a basketball for my birthday. Man did I have to beg for it too.
I use my iPhone cable with no issues for CarPlay.What are the benefits of a HDMI cable.
you can not use a HDMI cable in our cars with modifying the system. The lightning cable is fine
I did notice in a advertising video from across the pond that the Civic had a HDMI port.
1 - 18 of 18 Posts
