1 - 10 of 10 Posts
Hm... that'll be a tough one, the main thing to see is if there is an existing harness that's just sitting there, which I actually doubt. But if there is a harness, it'll be plug and play theoretically. Someone that has one needs to chime in to figure this out or you can just pop off your mirror and take a little looksie
Discussion Starter · #4 ·
Picked up the mirror glass worst case I guess I could run new wires through the door and either hook up to a rocker switch or splice into the defrost button. Will have to try and find a wire diagram.
Just make sure you wire it up clean, seen way too many hack jobs in my time, guys cutting through insulation or rubber seals just to feed wire rather than feeding it through how OEM or professional shops would.
1 - 10 of 10 Posts
