I was just wondering since our car is so new. Is anyone running a Hondata Flashpro? if so how is it, pro and cons? other then more HP
I have it and am running the Hondata +6 psi High Octane tune. Its fine for what it is, it definitely makes the car faster and ups the boost, but it maxes at 19.5 psi when it should be 22 based on the +6 psi tune. This is how the ecu works, so it will change timing and ignition and boost so its a net sum 0 gain after 19 psi on the Flash Pro with that tune. Im switching to Ktuner V2 which I bought from Michael Hinton and Axion and going to have Vit from vittuned.com e tune it. @Deathklok here has both as well and he prefers his Ktuner as well. Much more a tuner can do with Ktuner right now than Hondata allows with FlashPro. If you still want a Flash Pro, I will have mine for sale when my Ktuner comes in, hopefully in a week or 2.
sure, pass it my way, How much are you selling it for?. But isnt it registered to your car? You could transfer? Also anything i should know before hand?
They are $695 new, I'll let it go for $550 shipped. They can only be locked to one VIN at a time but If you want it Once my V2 comes, Ill unlock it from my car and send a screenshot showing "unlocked from vehicle" then you will be able to lock it to your car when you get it. Its easy to use and Hondata has "how to" videos as well. If you know how to plug in a USB cable and use a computer you can load/flash any tune to your car
FYI, if you dont buy mine but you still buy a used one, if the seller wont show you the "unlocked from vehicle" picture or wont you give the serial number, dont buy it. I believe you can verify with Hondata if a FlashPro is locked to a vehicle at that time. You would be buying a brick that wont work. And when you pay, use PayPal and pay the fee to pay as "goods" its the only way to protect yourself, and myself or any other seller from any fraudulent transaction.
Edit: to add, Hondata will not unlock any flashpro that is locked to a vehicle, under any circumstance.
