Just got my tire replaced. Drove half mile and got low tire pressure warning. Checked everything out and it is all fine. Recalibrated tpms and it cleared the warning on the dash, now the head unit is still getting the notification. Swiping down on the on the display doesn't let me clear it. It seems the message is stuck in the hondalink. Any thoughts how to clear?
It will clear after 30 minutes of driving. SOmetimes it takes two calibrations to make it go away. I dealt with it when I got my 19s and when the messed with my pressures at an oil change
Reactions: Deathklok
If the notification is only on the touchscreen, you may have to just hold the power button down and reboot it ... I've been having minor glitches since I bought the car just on the touchscreen. I had the TPMS issue once half way through a 300 mile trip. I went to the dealership. All they did was check the pressure and reset it. Hasn't happened again since. Sometimes, the tires might have just a slight bit of circumference difference that will play mind games with the abs sensors which will trip the TPMS. You may have to just keep attempting to calibrate it until you find the lucky reset where it finally goes away.
Or swipe the yellow envelope down then hold and force quit the app.
