Has anybody found some decent in-channel window visors specific to the hatchback? I have seen a lot of bad reviews related to the weathertech ones, and cannot seem to find any others that are reliable/worth installing. Any suggestions?
I have a 2018 Civic Hatchback Sport Touring, & was considering getting the side window visors, as you can get water inside when it is raining, with the windows down even just a tiny bit. I don't smoke in the car now, but did years ago, & wanted windows down a little to vent out smoke, or even for just a little fresh air. On previous cars, the "glue on" with sticky strip ones would come loose & come off in hot weather. I have read in previous comments, here or elsewhere that the better mounting in channel ones, can have problems when using the window auto up mode, as they can block the windows from going up 100% of the way, & create problems. I would do a little research to see if that has been a problem for your model car. WeatherTech usually has good products, but in-channel ones may not be compatible with auto up windows.
most of the issues are owners don't follow the instructions correctly. best to install in warmer/hot weather. install, keep windows up for the specified time so they can get set in place. i've had my weathertechs for years now...maybe twice....i've had an issue with the auto up feature.
