The Fog/Driving lights? where did you get them
Yes those, and I got them on Amazon click the amazon link belowThe Fog/Driving lights? where did you get them
They look quite a bit brighter than the stock fog lights.This is how they look, day time and night time.
Not sure if they are brighter, or if the fact they are white, not off white, makes them look brighter. The stocks were 35w these are 30w. The package is labeled as fogsThey look quite a bit brighter than the stock fog lights.
Thanks! Post yours when you get them done!I plan on doing this as well...looks great!
well i wouldnt say they're unsafe for the car... I think it's less of an issue with fogs. The article in question seemed to be geared towards head and tail lightsI wish I had seen this first, but better late than never, and now that I've read it, I'll be REMOVING the LED fogs I installed on the car, and putting back the OEM bulbs.
Even though I don't like how they look, they are safe for the car.
PLEASE read if you plan on changing your bulbs:
http://www.thetruthaboutcars.com/20...ersing-world-led-retrofit-bulbs/#more-1014818
I looked at them myself and did not see them to be painful to look at, or brighter than the headlights are.I was gonna say, "are these going to blind oncoming traffic?"
But it does say about dissipating heat properly. Driving/fog lights can be on just as long as the headlights are if you choose. So they could possibly cause heat build up is my fear?well i wouldnt say they're unsafe for the car... I think it's less of an issue with fogs. The article in question seemed to be geared towards head and tail lights
Just so it's clear: the problem with LEDs is not that they run anywhere near as hot as halogen/incandescent. The problem is that they are way, way, less tolerant of running hot. And that hot is hundreds of degrees cooler than the normal operating temperature of the halogens or incandescents.Thats why I bought Samsung's with the alloy heatsinks and lower wattage. They are temperature stable and produce less heat than the OEM's.
Isn't there also a concern about the beam pattern of LEDs vs Halogens in a housing that's designed for halogens? Those LEDs look like they're projecting pretty high for a foglight...Just so it's clear: the problem with LEDs is not that they run anywhere near as hot as halogen/incandescent. The problem is that they are way, way, less tolerant of running hot. And that hot is hundreds of degrees cooler than the normal operating temperature of the halogens or incandescents.
Yes, but instead of buying 60 Watt or 30 watts, I bought 15W bulbs made by Samsung and have lots of heat dissipation. I think you get in trouble when you try to buy super bright bulbs. Those are definitely going to be less heat tolerant because they produce a ton of heat on their own.Just so it's clear: the problem with LEDs is not that they run anywhere near as hot as halogen/incandescent. The problem is that they are way, way, less tolerant of running hot. And that hot is hundreds of degrees cooler than the normal operating temperature of the halogens or incandescents.
