I would be pretty upset. This is something that has to be covered under warranty. Is your headliner getting soaked ?
Just make sure you're able to pin point exactly where the leak is coming from, that way there's no time wasted and they have no reason to tell you they didn't find anything.Purchased 2016 Honda Civic in February. June 28 1st visit with leaking sunroof. Honda replaced sunroof. Middle of July leaking sunroof. August again leaking sunroof. Honda seems to not be able to duplicate the issue. I have done a water test with a hose and water does come in. When I am driving around town the water doesn't seem to want to flood my vehicle. It only likes to flood in a park under trees. Keep in mind where I work and live I have trees everywhere... I am at a loss of what I should do. Honda can't fix and says they have no issues on bulletins.. Help!!
Going to one of those flagship dealers that get the most volume and overall actually care about the customer experience is the way to go. Those guys are in it for the long term, hoping you'll actually come back for all if not most maintenance jobs.The dealer only matters with regard to the service and customer service they provide. It would appear that they are not in your corner concerning a serious problem with your new car. Knowing the dealer helps others to steer clear of a dealer who does not go to bat for their customer. Hope you get the matter resolved.
As a retired veteran (82nd Abn Div during 'Nam), I ask that you lighten up. My interpretation is that you were not called a liar, but rather the statement (from the manufacture) that they were supposed to leak, is a lie. Don't be so thin-skinned that other opinions get to you - you already know what opinions are like.The Dealer is of little matter . The Manufacture was the sayer of the matter. I am used to being called a liar I am a Veteran so I would expect nothing less from you. Look this is not a issue for anyone who checks there sunroof and it doesn't leak, for the ones that check and it does then you know. I am just saying what I was told no accusations other than if it leaks or seeps now then when the seal wears it will leak worse.
So take it as you wish good or bad.
I'm pretty darn sure 4Tires was referring to the dealer, and the dealer only.0What? I've never heard of a leaky sunroof being a feature and that seems like a boldfaced lie. Did you hear it directly from Honda Service USA?
Sorry for my poor choice of words. I was calling your dealership a liar, not you. I just find it weird that the manufacturer is saying that leaking and seeing is fine and it's normal.The Dealer is of little matter . The Manufacture was the sayer of the matter. I am used to being called a liar I am a Veteran so I would expect nothing less from you. Look this is not a issue for anyone who checks there sunroof and it doesn't leak, for the ones that check and it does then you know. I am just saying what I was told no accusations other than if it leaks or seeps now then when the seal wears it will leak worse.
