Some folks pay no mind and it doesn't bother them to have License Plates drilled into the front of their vehicle, others are quite the opposite.
I'm one of the folks who was lucky enough to get mine without the holes drilled (Had to sign off on it as well). Now it's a matter of coming up with an idea to mount without having to drill holes or block the inner-cooler at all.
The location bottom left in-front of the horn is the only spot that seems to come to mind but it's going to be tight.
Idea's? Suggestions? Where did you (if not default location) mount your LP on the front of your 10th gen?
Your input comes with free gratitude, thanks :)
I may have found a non-drilling option which will still put the plate in close to the stock position using a $6.50 bracket I found on ebay. If I get it to work, I'll post info and pics!
