So the Civic catch can is designed to keep the valves clean?
In a way, yes. The primary goal of the catch can is to catch any oil that tries to make its way through to the intake tract. This can prevent the valves from getting as much debris and keeps them cleaner longer!So the Civic catch can is designed to keep the valves clean?
Cool content! This is definitely a preventative measure to prolong any buildup on your valves and intake.some people are saying if it's so important why don't car makers include it right from the factory, which i'm sure some of you are thinking right now, this video delves into more on the catch can system:
http://www.youtube.com/watch?v=3KrSn3BoeLE
when it comes to preventative things like this, you really can't go wrong, a little goes a long way.
The can we are using within this kit is our compact baffled unit, which is designed without a sight glass. We've found that this catch can offers the most efficient separation, which is why it is used within all of our direct-fit kits. When designing this product, we found the addition of a sight tube or dipstick was not aesthetically pleasing. We were looking for a clean, factory-like catch can.Why OEM's don't include an oil catch catch? That's easy...because the owner must periodically empty the catch can! Do you think most owners would do that, or would just let the thing fill up and overflow? Some folks never open the hood. If the can is allowed to overflow, blow up, leak, or whatever, then oily residue would be released into the environment, and the EPA nannies would explode!
Thanks Mishimoto! Is the two ounce capacity enough though? If daily reasonable driving would require dumping the contents monthly, I guess that would be OK. Could a sight glass thing be installed to give a visual clue when it's time to dump?
Would probably require simple hand tools:How hard is tit to remove the catch can and put it back in after emptying it? Can it be done by anyone without tools?
It's easy! @CivicDuty pretty much has it down! The clamps and hoses get disconnected, the top gets detached from the bracket and the base gets unscrewed. Then you can pour out the contents of the can. We will go more in detail about how our cans work very soon. Stay tuned!How hard is tit to remove the catch can and put it back in after emptying it? Can it be done by anyone without tools?
Are these catch can's for Turbo's, or more for direct injection engines? Would this get much oil with easy light commute driving?
Great questions! Any vehicle can benefit from a catch can system. Turbocharged applications can see added benefits due to the increased amount of air and oil vapor that surges through the system. Stop-and-go driving situations can benefit just as much as highway driving with respect to gathering oil contaminants. @CivicDuty you hit the nail - or nails - right on the head!!!Is it cost prohibitive to put a small valve at the bottom of the catch can, so we can just empty the oil into a cup really easy??
A valve would make this a much easier job especially in cold climates where we don't want to be dis-assembling hoses and physically removing components
thanks
The presale will be going live VERY soon, so all of the pricing information will be updated in our next announcement for this project. Stay tuned!What is the retail price going to be
Thanks! Unfortunately, as of now, we do not have a direct fit kit for that application.Looking good. Do you have a direct fit system for a 2015 Si?
