1 - 7 of 7 Posts
I'm not happy with myself. Threw on my Yakima bike rack to transport my friend's bike to my place I took off the rack and found two chips right through to the plastic on the spoiler. I have attached the image below. I bought some touch up paint from the dealership when I picked up the car just in case. I'm going to dab some on just to make it not as obvious. Obviously I'm going to get it fixed. Should I put the touch up and see if they can blend it in by buffing at the dealer? Or is this something that will need to be taken to a body shop for? Strangely enough this was the second time I used the rack.
When I couldn't place a mountain bike type 10 speed without touching the painted portions of the rear bumper, I quickly discontinued it without getting a second person.
I did the same thing :(
If the paint from the dealer is the one like a felt pen its a one use item as the felt freezes when the paint dries. If its the brush in bottle one snap the end off a round toothpick and use it to dab paint in the chip not all over it. It takes a few applications to fill the chip.
I have used this method in the past and it will look better than how it looks now, but you will still be able to see it.
That's the best method to use. If you want a detailer to try and buff it down after, you'll have to fill the chip all the way to the top until you have a little crown type of ordeal, and then they can cut it down and smooth it out. Takes some time and patience though, you can't rush with this!
I was able to find a good paint match kit on amazon as well, you just need to find the paint code. it really handled the chips I put in my vehicle well.
1 - 7 of 7 Posts
