I don't recall seeing over 16PSI when I was stock...Now with Hondata +6psi it holds steady at 22psi in Sport mode + no-lift shift enabled means the boost doesn't drop between gears.
I tried +9psi yesterday...lots of tire spin in 2nd, 3rd held on but could feel light clutch slip. Cannot go WOT 4-6 without major clutch slip. Even with all this I managed 0.5s faster 50kmh - 100kmh run in 2nd to 3rd (4.8s with +6psi, 4.3s with +9psi. stock 5.4s)
If you want to have fun in this car, a clutch upgrade is recommended. Some folks have even had their clutch slipping at stock power levels; I have not. Might just be lucky, but certainly followed the new car procedure to break-in the engine and clutch.
