Are you unhappy with the suspension in your current Civic?I'd like to see the R18 get DI or even a turbo.Better suspension would be nice also.
Maybe thicker sway bars and tighter steering wheel ratio and with sport suspension shocks for the Si included and not just as an additional upgrade...I am wondering if it was too soft or too tight. DO we have any idea if the suspension will be changed for the next generation Civic?
I can't find anything on it through Google right now.
Was this a common complaint with the 9th generation Civic?
Did you meant the hfp suspension? Because the Si shocks were not available as an option to the non Si's...If the concept is any indication of the inspiration behind the next Civic, you would expect them to give a tighter and sportier suspension. Would including the Si shocks instead of making them an option raise the price much? I just wonder because that is likely a consideration that Honda is going to make.
