It's been awhile in the making, but we finally got our first shipment of SiriMoto Rear Sway Bars for the 10th Gen Civic! Also known as an Anti-Roll Bar, this SiriMoto Sway Bar Upgrade is designed to greatly reduce body roll and allow for better vehicle rotation. In short, it improves your Civic's handling when it comes to taking corners. This bar is available for the 2016+ Civic Sedan, Coupe, and Hatchback models. We tracked tested this part and I have personally felt the huge difference it makes in effectively taking corners.
Key Features:
  • Made from 20mm thick solid steel for the ultimate in rigidity.
  • 2 point adjustability means you can customize the stiffness to your specific needs (street or track use).
  • Direct bolt-on replacement to OEM Anti-Roll Bar.
  • Comes with high performance bushings.
  • Covered by a 1 Year Limited Warranty.
  • Brilliant red finish for added protection.
  • Includes necessary brackets and lubricant.
Product link to purchase and for more info: https://www.procivic.com/pages-produ...089/index.html
We do have a special introductory promotion going on for these, so PM me if you're interested!
