It depends on your tire size.
If you go with tires close to OEM specs, you MIGHT rub. (but probably not)
If you go with tires smaller than OEM, you probably won't.
I'm running 18x10 +20 with 225/40r18 on air.
I only rub when I'm at the lowest setting, but
at "lowering spring height", I don't rub at all.
