After a day of running wire in the blistering heat, I'm taking a break! I have my constant and switched power wires run from the trunk to under the dash and I'm looking for help finding connection points.
I'm connecting a small powered sub and the power connections for this model are made inside the cabin and not at the battery, presumable usually behind the head unit. Since I'm not replacing the radio, I pulled down the lower dash panel and was looking at the fuse box and this thing is pretty sealed up. Any suggestions for constant and switched power?
