Looking to upgrade your Civic's braking performance? Then Power Stop Z23 Evolution Sport Brake Kit would be your best bet! It offers more pad bite than other leading brands without noise and dust. All its components are made from the highest quality materials and are precision machined, molded and carefully slotted for a perfect fit. Power Stop has simplified your brake job by including everything you need for quick and easy installation in the box. Our tech expert Greg will tell you more about its components, specifications, benefits and installation requirements in our new video review.
Find Power Stop® - 1-Click Z23 Evolution Sport Drilled and Slotted Brake Kit at CARiD.com
Features:
- Precision machined using a Tru-Cast™ technology
- Rotor run out is within 0.0015 and DTV tolerance specification is within 0.005
- All Evolution rotors are mill balanced
- Rounded slots keep a clear contact patch between the pad and the rotor by sweeping away water, gas and dust
- Beveled and precision drill holes help keep rotors temperatures down during extreme braking performance
- All drilled and slotted rotors (except for hub and rotor assemblies) are silver zinc plated to helps shield and resist rust during normal operation
- Pads, rotors and clips are designed in the precise size and shape of factory OEM parts for proper fit and operation - Carbon Fiber infused Evolution ceramic formula for superior braking power
- Brake pads and rotors offer eliminate squealing under the most extreme cold or hot temperatures
- 3-year/36,000 mile manufacturer limited warranty on the rotors and pads purchased and installed together.
Navigate here for all Power Stop Performance Brake Kits, Pads, Rotors, Calipers at CARiD.com
Enjoy noise-free reliable braking with Power Stop Z23 Evolution Sport Brake Kit on!
