@ 5TAR: Yes, most certainly. Regular inspection of tread depth when doing rotations will help indicate issues with alignment and tire inflation. With my 2007 Civic I found that tire wear was better and more even with the tires inflated to 36 psi (cold - like before being driven for the day, not a few minutes after driving) instead of the 32 psi that the tire placard called for. Also with that car regular tire inspection showed that there was an alignment issue with the RR tire that caused that tire to scrub and feather slightly even though the car drove and handled fabulously. A few trips to my favourite alignment shop and a replaced lower arm (no prior accident damage found, but replacing the lower arm brought the alignment into correction) solved the issue. People tend to neglect their tires, and as they cost so much today and don't seem to last I try to get the most out of them that I can, but I also tend to stick with better performing tires over cost conscious tire choices. I put 60,000 miles on the 2007 Civic over (22) months and I managed to get close to the retail value for the car when trading it in on my 2017 Hatch.
@ B20Vtec: I've used Motul in motorcycle applications only, but I've also used Red Line and Amsoil in bikes. My most recent ride was a 1992 Yamaha FJ1200, and it had 70,000 miles on it when I bought it. . . Much forum discussion indicated that for that particular bike Shell Rotella 5W-40 Synthetic was the best oil for high mileage air-cooled bikes. I rode that thing to 98,000 miles and my father-in-law still owns it and it has over 115,000 miles on it now, and it neither burns nor leaks any oil, nor has the engine been open, ever.
For cars I've experimented with Amsoil, Mobil 1, Castrol Syntec, and Royal Purple. I was always amazed at how filthy the Syntec looked when it was drained and I haven't touched it in (15) years. Mobil 1 is inexpensive as compared to many other brands and is available literally everywhere (Costco even carries it, although the price there isn't a huge savings over Wal-Mart), and I really feel like Royal Purple is more ideal for racing applications than a commuter car. I've been using Amsoil for the last (5) years based on reading (comparison tests) and my favourite metric: appearance after 5,000 miles. It tends to come out only marginally dirty to my naked eye, and when I pour out the waste into my transport jug there isn't ever ANYTHING nasty at the bottom of the pan like there was with Syntec. I'll admit that I change my oil almost too frequently; if you follow the indicator in the car it will have you change the oil (with assumed regular dino oil) between 6800-8500 miles, depending upon how you drive. I'm using a higher quality oil which should allow for longer life and a greater interval between changes, but I'm also not a wealthy man and I believe that better preventative maintenance is preferable to expensive repair or replacement.
But to your original question, sir: I've used Motul in air-cooled bikes and been satisfied with it. I live in Minnesota and the riding season is "short", and with the exception of my FJ I've never put really big miles on my bikes but I'd still change out the oil every spring as storage can be hard on the lube. Motul is fairly well rated and seems to be well liked from what I've read, but my experience with it is fairly limited so I can't really offer a solid opinion.
Sorry I didn't answer that with just the last sentence; I tend to go on about things.
