What I read in another forum about this, is leave it alone, it needs as much air as possible
What I read in another forum about this, is leave it alone, it needs as much air as possibleThe bottom opening for turbo intercooler and condenser is wide open to stone chips, rocks, tar and other debris that can fly in there with highway driving.
would it be a good idea to tie wrap some gutter guard in front of it? there should still be airflow but would block larger rocks from doing damage.
I know my 2006 civic condenser looked like Swiss cheese from 170k miles. it caused the AC to leak out and many people had issues with it.
see attached - I would just cut into two strips, one for top, and one for bottom and use black tie wraps to secure it
I bet it will, these things are built to last with the mass market and i'm sure they did hot weather testing to ensure it will hold up.If it can handle 117 degree Arizona, I will take my chances and maybe just use it from November thru April in north east.
you could always cut it off before bringing it inIf you put that in, and something happens to the engine or the intercooler, they'll blame your mod and not cover it under warranty
Am I wrong to say the intercooler only gets hot (and needs the most cooling) when you are really using the turbo (accelerating)? If thats the case I won't have much issue because most of the time I am a hypermiler trying to avoid any heavy acceleration. I only need it when entering the freeway.
Note: by not doing this protection grille, you will eventually have airflow restriction anyways from all the bent pins from rock damage. Will need to straighten the fins periodically
I'd like to think if this were truly an issue, Honda would have dealt with it?Protection is important for the intercooler. Nobody wants to have everything torn apart to replace an expensive intercooler that is not easy to get to. Come to think of it I would even consider a metal custom framed window screen to avoid all the small rocks from smashing the fins.
Perhaps for extreme conditions like yours yesYou are probably right..Honda designs for normal driving conditions, but I drive through construction zones all the time. Unfortunately I can't change my commute right now
However, MANY people had problems with their condensers leaking in Gen 8 Civics from rock damage. It usually doesn't show itself until well past the 36k mile warranty. I would say it happens after about 90K miles for us commuters in the rust belt where there is always road repair, gravel, rocks.
