Service bulletin 16-022 Audio unit device update
6112 Views 3 Replies 4 Participants Last post by  Chris Malone
Hopefully this will fix most of the problems people are experiencing.
Reactions: 2
Thanks for posting up the service bulletin! Maybe this will help with the Android Marshmallow Bluetooth problem.
In case someone can't get to the file, here's the gist of it. Also, it's affecting both the coupe and the civic sedan.
BACKGROUND
There is a problem with the audio unit software, which may lead to one or more of the following symptoms:
• Bluetooth® Audio skips.
• Audio icon does not work.
• GPS error code 1302 sets.
• Error message SXM check tuner appears.
• GPS initialization screen appears.
• Rear camera is stuck on in Park.
• Bluetooth® HandsFreeLink®
(HFL) pairing
problems.
• Rear camera does not display.
• There is no sound from Apple CarPlay™ after
connecting Bluetooth®
, then USB.
• System does not recognize “SXM” in voice
commands.
• Pandora® does not play after HFL call ends.
• Voice commands do not work.
• Android Auto™ will not play.
CORRECTIVE ACTION
Update audio unit software using the audio-navigation system USB update device.
I have the one that says "Check Tuner"
Just got this done today. Bluetooth and android auto was basically useless and i called the dealer and was told about the update. Came in same day and we will see if it helps. So far so good.
