Hey everyone,
I've been having an issue with my steering where it'll return perfectly to the center from the left, but is a little off when turning right, and will not completely center out. I've checked my tire pressure and it seems good. My car has about 13,500 miles and is only about 8 months old. I'll attach my current alignment specs, as I'm wondering whether or not the alignment is contributing to the problem.
Is this a common issue and if so how can it be corrected?
Thanks in advance!
This is not common, as you may know your car has electric power steering, and your centering is controlled by a computer/circuit board. This would be a fix performed at the dealer, you should be covered by warranty. Good luck, let us know how you make out and how they fix it. This info may be helpful to others in the future.
WIll do. I have someone coming tomorrow to check it out again. He originally suggested tire pressure but it wasn't that. I've been having this issue way too long and hope it gets sorted soon!
