1 - 10 of 10 Posts
Today, the display on my 3-week-old EX-L went bad. I know the Touring displays have been having problems, but I haven't heard of any problems on the "lesser" EX models.
When I started the car, the display stayed blank (totally black) for a minute and then would flash on/off. When I backed up, the camera view would flash on/off and would freeze periodically. The right turn signal view would also stutter.
It's like something is using a very high percentage of the CPU cycles and all display operations are slowed down.
I don't remember how (may have to go into diagnostics mode - audio+home+menu buttons) but you can go through the unit and turn off applications that you don't use, like android auto/carplay.
I think its possible that the head unit doesn't have the capability to run the audio and nav and possibly sensing (although I think that's separate) on top of everything else.
But I don't have nav and sensing on my EX-L.
The amplifier in the Touring had an issue with no audio on power-up. There is a TSB, 16-1, for cars produced before 12/18 (2* VIN) or 12/16 (1* VIN), for a firmware update to the amplifier. That amplifier is only used in the Touring.
Other infotainment issues, display or otherwise, seem to be equal opportunity bugs across all Display Audio trim levels.
Yea I've heard of issues with the infotainment system in all models sadly. Sounds like one of those things that will be fixed in the second model year. That's why it is nice to wait to buy and let others deal with these early issues.
Discussion Starter · #6 ·
I started the car a couple of times today and the display seemed normal. Go figure.
I tried your diagnostic modes tip and there were no apps running. At least today -- I don't know about yesterday.
Same problem here! Although, I live in Toronto, CAN so I was thinking the cold weather might've had something to do with it. But cold weather or not, it does seem peculiar for the screen to have problems given it's a brand new car. After driving a bit though, it usually seems to even out. Definitely bothersome initially.
That point is even more valid since car makers do extreme cold and hot weather testing so issues like this shouldn't come up, it's something they should have weeded out with that testing.
1 - 10 of 10 Posts
