No, there aren't. It's sensor-less. Uses info from the ABS sensors. That's why there is the whole calibrate/reset bit.
Correct. No sensors in the wheels.I'm assuming the tpm isn't in the valve stem...???
Fitment should be fine. Shouldnt have any issues. Same bolt pattern. My Ex-L came stock with 17's now have 18's. No issuesAny idea about fit ment? Civic should be at dealer by end of month. Civic has 16's. The accord has 17's. I'm worried about clearance and bolt pattern..
please keep us posted on how that looks, i've always been a fan of how wheels from other cars from the same manufacture look, especially when its a set of wheels that are quite attainable (unless you're talking about some aftermarket set that you used on your TL?That's cool .. then I can swap my TL wheels with no warnings , same with winter steelies .
6. Put the flat tip of the jack handle bar into
the edge of the wheel cover. Carefully pry
the edge and remove the cover.
> Wrap a cloth around the flat tip of the
jack handle bar to prevent scratches on
the cover.
