Hey everyone, on my 2017 civic I changed the theme to the other one that is installed on the car and I changed my wallpaper on it but I noticed it is very dim and I can't see it that well, I was wondering if there is a setting I can change. I am not very familiarized with the nav unit yet. And also the brightness is all the way up
Going to ask, just because it's something I'd do: are your headlights on?
:crying:The reset stick for your trip odometer control's the brightness for your dash and your head unit, as does as the top button on the head unit, but I think you will see that your background is bright and clear when you choose it but then dims as soon as the overlaying info appears.
Discussion Starter · #5 ·
That's the thing, it's on max brightness and the wallpaper is bright when switching between info but then when the overlay finally loads it prioritizes that instead of the wallpaper and it becomes dim
