Ok help me out quick, which Civics are available with LED's?
The Touring comes standard with the LED headlights. No other model comes with them as far as we know.Ok help me out quick, which Civics are available with LED's?
Well i'd assume the coupe will get a top of the line Touring trim as well, like the sedan. If they don't do a touring model coupe, then i'd imagine they'll have it as an option on upper trims. I imagine Si models will have them standard as well.Think they'll put the LED headlights in the Civic Coupe or at least have it as an additional option for it?
If they go for an entry-level approach to the layout of the LED setup then it could be standard, they just can't make it all intricate and complex. It's an entry-level model so we should expect entry-level things to be happening.Think they'll put the LED headlights in the Civic Coupe or at least have it as an additional option for it?
I'd be happy if the projector setup had LED bulbs, just so they match the accent lights. I wonder if super white halogens would be close in color to the LED or if i'd have to make a switch to xenon in order to get a closer color match to the accent lights.If they go for an entry-level approach to the layout of the LED setup then it could be standard, they just can't make it all intricate and complex. It's an entry-level model so we should expect entry-level things to be happening.
True stuff. And i know you can't... but i do know its relatively easy to get xenon bulbs that match the blueish tint of LED lights and those aren't hard to switch over at all.I bet plenty of people will get the lesser model and then try to upgrade the lights. I can just see it now, the threads where people ask if they can just buy the LED lights and install them.
