1 - 7 of 7 Posts
Hello all,
How do you all manage to clean your windows? I used chemical cleaners to clean my windows and now my window has lost its shining appearance. It also has hard water spots. I recently found an article by replacement windows Ottawa. It says to go with eco-friendly methods of cleaning. What method do you prefer for cleaning? How can I get rid of these hard water spots?
Hello all,
Inside
Outside
hope this helps! I personally follow this practice, ZEP cleaner is my go to.
I used magic glass it's a alcohol base.
Hello all,
The reason its lost its shine is because of the mineral deposits and same with the water spots .. Usually regular window cleaners wont remove them.. Try white vinegar and if that doesn't work look for the waters spot remover for glass made by DuraGloss 755 . Once removed .. in the future always dry your windows when you wash it. Most water spots come from tap water.
Your paint prolly has lost some of its gloss too for the same reason.
1 - 7 of 7 Posts
