Guys,
Just finished installing XenonDepot HID kit (4300K Phillips bulbs).Installation was easy, a lot of room behind headlights, no problem removing halogen bulbs and installing HID bulbs. Ballasts secured with double zip ties and all looks solid. Test drove it and I believe the level of adjustment is very high.If I hit the gas pedal a bit I see the light in a cabin of car in front of me.I notice if the distance is less then 20-30 feet from car in front of me its not that bad, but when distance increased I believe light trow tend to go up. Any recommendation? Should I try level adjustment?
Thanks.
Guys,
Thanks.
I'm thinking about purchasing this kit, would you happen to have photos of the install??
where did you bolt the grounds and zip tie the ballasts??
See if you can park behind another parked car and level them? BTW can we see pictures of the light output in the night? :)
